Suzuki Rückrufaktion vom 16.02.2011
Автор paul23, февраля 27, 2011, 20:51:43
ЦитироватьSome regulator/rectifier assemblies were produced with insufficient adhesion between the power module (circuit board) and the rectifier case that contains a heat sink to dissipate heat. Due to insufficient adhesion, heat generated on the power module circuit board can cause the circuit board to deform and lift off the case. This condition causes excessive heat on the circuit board and uncontrolled electric current output, which can result in insufficient charging current being provided to the motorcycle battery. This can cause discharge of the battery and can lead to engine stalling and/or a no-start condition.
Suzuki will notify owners, and dealers will replace the regulator/rectifier with an improved part for free. The recall is expected to begin on or about March 2.
quelle:http://www.dealernews.com/dealernews/LATEST+NEWS/Suzuki-recalls-more-than-70000-motorcycles-for-ele/ArticleStandard/Article/detail/709259?contextCategoryId=48447
с 2.03.2011 начнут всем письма рассылать и оффициально приглашать на замену реле-генератора  :coolbubble:
ну или по крайней мере должны начать  :D :D :D
